Difference between revisions of "Quartz64 Installing Arch Linux ARM"
m
Update the kernel package to a 5.18-rc kernel with PCIe patches
m
m (Update the kernel package to a 5.18-rc kernel with PCIe patches)
(One intermediate revision by the same user not shown)
Line 84: Line 84:
In <tt>/mnt/alarm-root/etc/fstab</tt>, put the lines
  PARTUUID=''root-uuid-here''  /      ext4    defaults        0      0
  PARTUUID=''root-uuid-here''  /      ext4    defaults        0      1
  PARTUUID=''boot-uuid-here''  /boot  vfat    defaults        0      1
  PARTUUID=''boot-uuid-here''  /boot  vfat    defaults        0      2
with your UUIDs in place of the placeholder.
Line 112: Line 112:
{{note|Here's where you'd do the part I said was iffy and won't be necessary once my PR is merged. You'll need an Arch Linux or Manjaro system. If it's not an aarch64 system, you'll also need <tt>qemu-user-static</tt>.
First, get [https://overviewer.org/~pillow/up/aca7520ff4/linux-aarch64-5.17.1-2-aarch64.pkg.tar.zst the linux-aarch64 package I patched and built], then copy it somewhere into your mounted root.
First, get [https://fratti.ch/quartz64/alarm-kernels/linux-aarch64-rc-5.18.rc6-1-aarch64.pkg.tar.zst the linux-aarch64-rc package I patched and built], then copy it somewhere into your mounted root.
Alternatively, patch and build the package yourself by [https://github.com/archlinuxarm/PKGBUILDs/pull/1918 applying this PR].
Alternatively, patch and build the package yourself by [https://github.com/CounterPillow/PKGBUILDs/commit/622e03ba3753f823ea903bdbbf59c2f400dd2334 using my forked package sources].
Next, <code>arch-chroot</code> into the mounted root:
Line 122: Line 122:
and install the package
<code># pacman -U linux-aarch64-5.17.1-2-aarch64.pkg.tar.zst</code>
<code># pacman -U linux-aarch64-rc-5.18.rc6-1-aarch64.pkg.tar.zst</code>
Then <code>exit</code> the chroot again once it's done installing.
504
edits
Navigation menu
