Difference between revisions of "Pinecil Hardware Debugging"
no edit summary
Line 1: Line 1:
This page is work-in-progress and is user-contributed content.
= Problems possible =
{| class="wikitable" style="margin:auto"
== Pinecil doesn't power on at all ==
! Issue !! Cause/Symptoms !! Possible Solutions
# Check your PSU - it might be faulty
# Check cable
|rowspan="3"|Pinecil doesn't power on at all
# Use different kind of PSU (if you're using a barrel jack one, try a Type-C one, and vice-versa)
|Faulty PSU
|Check your PSU with another tool or a multimeter
== Pinecil shuts down when connected to a Type-C PSU and trying to request a higher voltage ==
Title needs a bit more clarification
|Faulty cable
Update firmware - factory firmware has quite a few USB-PD problems, which the newer firmwares fix. See the [https://github.com/Ralim/IronOS/blob/master/Documentation/Flashing.md#pinecil-pine64 update documentation on GitHub]
* Check cable with another device
* Use a different cable
== Pinecil randomly resets when touching solder or doing other things ==
  - Using PinePower or some other non-grounded PSU?
|Internal problem with power
    - This is likely to be a "lack of grounding" problem. When using Pinepower, you can unplug the figure-8 AC cable plug (on the back), rotate it 180 degrees and plug it back in - this tends to remedy the problem [https://github.com/Ralim/IronOS/issues/975 (insights)]
== Doesn't power on after applying 24V to the barrel jack ==
| Pinecil shuts down when connected to a Type-C PSU and trying to request a higher voltage (Title needs a bit more clarification)
  - The FUSB302 might have gotten damaged and shorted an internal power rail
|Out-of-date firmware
    - Fix is to use a hot air gun to remove the FUSB from the board. You can leave the iron without the FUSB302 IC, or you can find and buy a replacement.
    - Without the FUSB IC present, you will lose USB-PD compatibility - the Type-C jack will not power your Pinecil with a C-to-C cable, or from a PD-capable PSU with attached type-C cable (laptop PSUs)
    - You will still have USB QC support without the FUSB IC, and all the other features will keep working!
== Pinecil tip heats up too much, starts to glow and [REDACTED] ==
  If you don't press the + button after plugging power in, does it start glowing?
  - If it heats up as soon as you connect power (without button presses), then it's likely a FET failure - the FET can be replaced. by using a hot air station or a soldering iron.
  - If it only heats up after pressing the button, this is likely to be bad soldering of the thermocouple amplifier IC caused such behaviour. Resoldering the thermocouple amplifier shoudl fix this problem.
|Damaged USB chip
  You will want to replace the tip after it's heated up to the point of glowing, as the surface coating is likely to have gotten compromised.
* Use a hot air gun to remove the FUSB from the board. You can leave the iron without the FUSB302 IC, or you can find and buy a replacement.
* Without the FUSB IC present, you will lose USB-PD compatibility - the Type-C jack will not power your Pinecil with a C-to-C cable, or from a PD-capable PSU with attached type-C cable (laptop PSUs)
* You will still have USB QC support without the FUSB IC, and all the other features will keep working!
|rowspan="3"|Pinecil tip heats up too much, starts to glow and [REDACTED]
| Heats up when plugged in, without pressing any buttons
| Likely a FET failure - the FET can be replaced. by using a hot air station or a soldering iron.
| Heats up after pressing the button
| Likely to be bad soldering of the thermocouple amplifier IC. Resoldering the thermocouple amplifier should fix this problem.
|colspan="2"| '''Either way, you will want to replace the tip after it's heated up to the point of glowing, as the surface coating is likely to have gotten compromised.'''
= Debugging instructions =
11
edits
Navigation menu
