Difference between revisions of "User:Fxc/Software Draft"
(New text)
Line 50: Line 50:
Flashing to the eMMC can be done by booting an operating system from the microSD and by writing to the eMMC directly from there:
# Boot an operating system from the microSD card. If there is already a bootloader on the eMMC installed see the section [[PinePhone Pro#Boot order]] to bypass it
# Boot an operating system from the microSD card. If there is already a bootloader on the eMMC installed see the section [[PinePhone Pro#Boot order|Boot order]] to bypass it
# Download or copy the desired image to the microSD card as file
# Check if the eMMC appears under <code>lsblk</code>. If it doesn't appear in the output of the command, the eMMC wasn't initialized due to applying the above explained bypass method for a too long time during the boot
Moderator
1,493
edits
Navigation menu
