Moderator
1,479
edits
(→First time setup: reduced size, simplified instructions) |
(→First time setup: order) |
Line 29: | Line 29: | ||
* When shipped the battery is isolated from the mainboard contacts using a protective plastic tab, which is required to be removed before using the phone. The battery '''will not''' charge until it is removed and some of the device’s functionality may not function properly. | * When shipped the battery is isolated from the mainboard contacts using a protective plastic tab, which is required to be removed before using the phone. The battery '''will not''' charge until it is removed and some of the device’s functionality may not function properly. | ||
* The PinePhone Pro's SIM slot only accepts a micro SIM, please '''do not insert an empty micro SIM adapter or a nano SIM''' without an adapter into the phone, as the adapter will get stuck on the contact pins and risk breaking them, while the loose nano SIM might short the contacts. The | * The PinePhone Pro's SIM slot only accepts a micro SIM, please '''do not insert an empty micro SIM adapter or a nano SIM''' without an adapter into the phone, as the adapter will get stuck on the contact pins and risk breaking them, while the loose nano SIM might short the contacts. The microSD has to be placed in the upper slot, while the micro SIM card has to be placed in the lower slot. An adapter from a nano to a micro SIM is included in the box. | ||
<gallery mode="nolines" widths="240px" heights="240px"> | <gallery mode="nolines" widths="240px" heights="240px"> |
