Difference between revisions of "PinePhone (Pro) Keyboard"
Add link to YouTube video showing how to shim pogo pins
(The given width of 21.5mm was significantly inaccurate, to the point of being problematic if these measurements are used. The actual width with the phone in the keyboard various from about 24.5mm to 25.3mm, depending on the edge the thickness is measured—it's slightly wedge shaped. 25mm should be a more useful value to those looking for dimensions.)
(Add link to YouTube video showing how to shim pogo pins)
Line 36: Line 36:
* Apply '''slight''' pressure in the upper mid of the PinePhone's backside until the plastic holder pin towards the upper middle of the keyboard cover, until an audible click can be heard.
* Make sure the contacts and pogo pins are clean and the pogo pins can be slightly pressed individually.
* If the above does not work, a shim under the keyboard's contacts might be required, as explained [https://xnux.eu/pinephone-keyboard/faq.html#ts FAQ troubleshooting section]. See also this [https://freiburg.social/system/media_attachments/files/107/684/243/421/870/279/original/a5e9c68ff3510ec8.jpeg photo of where to place the shim]
* If the above does not work, a shim under the keyboard's contacts might be required, as explained [https://xnux.eu/pinephone-keyboard/faq.html#ts FAQ troubleshooting section]. See also this [https://freiburg.social/system/media_attachments/files/107/684/243/421/870/279/original/a5e9c68ff3510ec8.jpeg photo of where to place the shim], or [https://www.youtube.com/watch?v=4ixPjz6SPIA this video].
==== Top row is less responsive ====
1
edit
Navigation menu
