Difference between revisions of "PinePhone Pro"
Line 287: Line 287:
* Download the build, extract the image and dd it to a 8 GB or larger microSD card, takes out the PinePhone Pro Explorer Edition then insert it into microSD slot (upper slot).
* Insert battery, press RE button (bypass SPI and eMMC boot)  while plug in USB-C power. After 3 seconds release RE button.
* When power up, below screen show up and press power key.
* When power up, below battery icon screen show up and press power key for two second, the Rockchip logo screen shows up.
[[File:PPP_Abdroid_Test_Utility-1.jpg]][[File:PPP_Abdroid_Test_Utility-2.jpg]]
* At the home screen, double tap on the test app (mark red circuit on below screen) and this will bring up teh factory test build. Please note that SD test is disable due to this is a SD boot build.
* Wait for home screen, double tap on the test app icon (mark red circuit on home screen) and this will bring up the factory test screen. Please note that SD test is disable due to this is a SD boot build.
* After running particular test function, please snapshot teh test result and pass back to support team
* After running particular test function, please snapshot test result and pass back to support team
[[File:PPP_Abdroid_Test_Utility-4.jpg]][[File:PPP_Abdroid_Test_Utility-5.jpg]]
Navigation menu
