Difference between revisions of "PinePhone Pro"
no edit summary
(→‎Boot order: style fix)
Line 276: Line 276:
** [https://files.pine64.org/doc/cert/PinePhone%20Pro%20CE%20RED%20Certificate-S21101902802-R1.pdf PinePhone Pro CE RED Certificate]
** [https://files.pine64.org/doc/cert/PinePhonePro%20RoHS%20Test%20Report.pdf PinePhone Pro ROHS Test Report]
== Factory Test Build for Hardware Checking ==
* Please note that this Android build solely for PinePhone Pro hardware checking purpose and solely used by support team. This is NOT a general release build.
* DD image (for 8GB microSD Card or larger)
** [http://files.pine64.org/os/pinephone_pro_dd_android9_QC_Test_SDboot_20220215-8GB.img.gz Direct download from pine64.org]
*** MD5 (GZip file): 214e063c8205c1a98d44b2015a21bb5d
*** File Size: 722MB
* Download the build, extract the image and dd it to a 8 GB or larger microSD card, takes out the PinePhone Pro Explorer Edition then insert it into microSD slot (upper slot).
* Insert battery, press RE button (bypass SPI and eMMC boot)  while plug in USB-C power. After 3 seconds release RE button.
* When power up, below screen show up and press power key.
[[File:PPP_Abdroid_Test_Utility-1.jpg]]
* At the home screen, double tap on the test app (mark red circuit on below screen) and this will bring up teh factory test build. Please note that SD test is disable due to this is a SD boot build.
== Press ==
== Press ==
Navigation menu
