Difference between revisions of "Pinecil"
Update notes based on my experience flashing IronOS 2.17 on the 2nd batch with the help of the forum.
m (Added: Charmast C2032 power bank.)
(Update notes based on my experience flashing IronOS 2.17 on the 2nd batch with the help of the forum.)
Line 189: Line 189:
=== Manually ===
=== Manually ===
(Method tested on Linux, should work on any OS which supply dfu-util 0.10, if your distro comes with 0.9 you might soft-brick your Pinecil)
Method tested on Linux, should work on any OS which supply dfu-util 0.10+.
{{note|1=If <code>dfu-util</code> command cannot find a device with 28e9:0189 ID, try to run it with <code>sudo</code>}}
# Use the command <code>dfu-util -V</code> to check your version.  If your distro comes with 0.9 you might soft-brick your Pinecil, install the latest stable release from [http://dfu-util.sourceforge.net/ sourceforge].
# Enter the update mode. For that, unplug a barrel jack PSU if you have one plugged in. Then, plug USB cable while holding *-* button (button that's closest to USB-C port). The screen may be blank which is fine.
{{note|1=To check if you can use dfu-util 0.9, you can use <code>dfu-util -l</code>. If it reports <code>alt=0, name="@Internal Flash  /0x08000000/128*001Kg"</code> you are fine, otherwise you need to upgrade to 0.10, important part is <code>128*001Kg</code>, which is flash amount of blocks and block size, as a chip used in Pinecil have 128 KB of Flash with 1KB page size}}
# Check that your Pinecil is available by listing devices with <code>dfu-util -l</code> and look for device with 28e9:0189 ID. Try running with sudo if your device is not listed. If dfu-util reports <code>alt=0, name="@Internal Flash  /0x08000000/128*001Kg"</code> you are fine, otherwise you need to upgrade to 0.10+, important part is <code>128*001Kg</code>, which is flash amount of blocks and block size, as a chip used in Pinecil have 128 KB of Flash with 1KB page size
# Make a firmware backup: <code>dfu-util -d 28e9:0189 -a 0 -U ~/pinecil/internal.flash.stock -s 0x08000000</code>
## <code>28e9:0189</code> -- USB Device ID (can be obtained from <code>lsusb</code> or <code>dfu-util -l</code> but in dfu-util output it might be hard to identify the Pinecil device)
Line 203: Line 201:
# Flash a new firmware: <code>dfu-util -d 28e9:0189 -a 0 -D Pinecil_EN.bin -s 0x08000000:mass-erase:force</code>
## <code>-D</code> -- is a mode to Download firmware to the device (yes, that's confusing, but you indeed Upload from device and Download to device with dfu-util). That should follow the file with the firmware. Update archive from Ralim usually contains two files: <code>.hex</code> and <code>.bin</code>. One that is required - is <code>.bin</code>. <code>_EN</code> is the language code of the firmware, means that <code>_EN</code> will flash english version of firmware.
## <code>-s 0x08000000:mass-erase:force</code> -- specified the address where to flash the file. <code>:mass-erase:force</code> is required to force-erase flash before updating firmware, otherwise you might have unpredictable results.
## <code>-s 0x08000000:mass-erase:force</code> -- specified the address where to flash the file. <code>:mass-erase:force</code> is required to force-erase flash before updating firmware with the first batch, otherwise you might have unpredictable results.
## If it fails with <code>Error during special command "MASS_ERASE" get_status</code> (as has happened with recent shipments) then use ...<code>-s 0x08000000</code> without attempting "mass-erase".
## If it fails with <code>Error during special command "MASS_ERASE" get_status</code> (as has happened with recent shipments) then use ...<code>-s 0x08000000</code> without attempting "mass-erase". Full command example: <code>dfu-util -d 28e9:0189 -a 0 -D Pinecil_EN.bin -s 0x08000000</code>
## If the hex and dfu files cannot be flashed, convert the hex file to bin with this command: <code>objcopy --input-target=ihex --output-target=binary Pinecil_EN.hex Pinecil_EN.bin</code>
== Disassembly steps ==
19
edits
Navigation menu
