1
edit
(→Operation: Charging can also be deactivated by double-clicking the button) |
(The given width of 21.5mm was significantly inaccurate, to the point of being problematic if these measurements are used. The actual width with the phone in the keyboard various from about 24.5mm to 25.3mm, depending on the edge the thickness is measured—it's slightly wedge shaped. 25mm should be a more useful value to those looking for dimensions.) |
Line 115: | Line 115: | ||
== Hardware == | == Hardware == | ||
Key hardware specifications: | Key hardware specifications: | ||
* Dimensions (closed): 161 x 95 x | * Dimensions (closed): 161 x 95 x 25mm | ||
* Weights (without / with PinePhone mounted): ~ 191 / ~391 grams | * Weights (without / with PinePhone mounted): ~ 191 / ~391 grams | ||
* Number of keys: 54 | * Number of keys: 54 |
edit
