Difference between revisions of "Quartz64PremiumAluminiumCase"
no edit summary
(Quartz64 Model A fitting in RockPro64 Premium Aluminium Case)
Line 14: Line 14:
[[File:quartz64a-rockpro64case-3.jpg]]
Also note that the SoC in the Quartz64-A is slightly lower than the Rock64 Pro one (apparently about 0.6mm).  This case includes an internal post which (using a thermal pad) touches the SoC to transfer heat from the SoC to the case.  However it does not make good contact with the RK3566.  The best solution is probably to source a thicker thermal pad.
47
edits
Navigation menu
