1
edit
m (Update Debian Installer to reflect current state more accurately) Tags: Mobile web edit Mobile edit |
(Add opensuse instructions) |
Line 241: | Line 241: | ||
Get the latest openSUSE Tumbleweed images for Pinebook Pro here: [https://en.opensuse.org/HCL:Pinebook-Pro-RK3399] | Get the latest openSUSE Tumbleweed images for Pinebook Pro here: [https://en.opensuse.org/HCL:Pinebook-Pro-RK3399] | ||
Credits to [https://bugzilla.opensuse.org/show_bug.cgi?id=1194491] | |||
Step 1. Flash Tow-Boot[https://github.com/Tow-Boot/Tow-Boot] to SPI | |||
Step 2. Flash openSUSE image to sd card & insert it | |||
Step 3. When it loads grub, press e and add the following line: | |||
devicetree /boot/dtb/rockchip/rk3399-pinebook-pro.dtb | |||
Press ctrl + x to boot | |||
Work : display, wifi | |||
Not tested : bluetooth | |||
Doesn't work : audio | |||
You may build rpms and see if it fix issues from this repository: [https://github.com/bengtfredh/pinebook-pro-copr] | |||
== FydeOS == | == FydeOS == |
edit
