Moderator
1,479
edits
(Undo revision 12469 by Boot loop (talk) Text is not seen under the images, order is order of importance and how recently issues come up. Stop pushing stuff around, thanks. There is a reason why stuff is ordered a specific way) Tag: Undo |
(→First time setup: added a sentence) |
Line 30: | Line 30: | ||
== First time setup == | == First time setup == | ||
Before the PinePhone Pro is taken into operation, the following information has to be considered: | |||
The PinePhone Pro's SIM slot only accepts a micro SIM, please '''do not insert an empty micro SIM adapter or a nano SIM''' without an adapter into the phone, as the adapter will get stuck on the contact pins and the loose nano SIM will short the device! The SIM card has to be placed in the lower slot, while the microSD has to be placed in the upper slot. An adapter from a nano to a micro SIM is included in the box. | * When shipped the battery is isolated from the mainboard contacts using a protective plastic tab, which is required to be removed before using the phone. The battery '''will not''' charge until it is removed and some of the device’s functionality may not function properly. | ||
* The PinePhone Pro's SIM slot only accepts a micro SIM, please '''do not insert an empty micro SIM adapter or a nano SIM''' without an adapter into the phone, as the adapter will get stuck on the contact pins and the loose nano SIM will short the device! The SIM card has to be placed in the lower slot, while the microSD has to be placed in the upper slot. An adapter from a nano to a micro SIM is included in the box. | |||
To remove the sticker after unboxing the phone: | To remove the sticker after unboxing the phone: |
