Difference between revisions of "PinePhone Pro"
m
→‎First time setup: : reordered sections so that it's [info about battery] [info about sim] instead of what is currently there ([info about battery] [info about sim] [back to info about battery]). This is a change I already made recently but was reverted by Fxc where he reverted other larger changes, I think that's fair but I can't see a reason why this would be reverted. Would like to discuss this change but don't know how to message Fxc. Why revert this change ?
(→‎Components: reordered list)
m (→‎First time setup: : reordered sections so that it's [info about battery] [info about sim] instead of what is currently there ([info about battery] [info about sim] [back to info about battery]). This is a change I already made recently but was reverted by Fxc where he reverted other larger changes, I think that's fair but I can't see a reason why this would be reverted. Would like to discuss this change but don't know how to message Fxc. Why revert this change ?)
Line 31: Line 31:
== First time setup ==
When shipped the battery is isolated from the mainboard contacts using a protective plastic tab, which is required to be removed before using the phone. The battery '''will not''' charge until it is removed and some of the device’s functionality may not function properly.
The PinePhone Pro's SIM slot only accepts a micro SIM, please '''do not insert an empty micro SIM adapter or a nano SIM''' without an adapter into the phone, as the adapter will get stuck on the contact pins and the loose nano SIM will short the device! The SIM card has to be placed in the lower slot, while the microSD has to be placed in the upper slot. An adapter from a nano to a micro SIM is included in the box.
Line 45: Line 43:
Image:Pinephone_backside.png|The microSD belongs in the upper slot, the micro SIM in the lower slot.
</gallery>
</gallery>
== Software ==
== Software ==
11
edits
Navigation menu
