10
edits
(The CPU is actually Overclockable and Undervoltable with good benifits. Added a basic description.) |
(560 doesn't work on my Pinephone) |
Line 36: | Line 36: | ||
{{note|The file may be slightly different and you may need to enter the values as hexidecimals}} | {{note|The file may be slightly different and you may need to enter the values as hexidecimals}} | ||
{{hint|The GPU appears to run stable overclocked to | {{hint|The GPU appears to run stable overclocked to 540 Mhz, however more testing with a wider group of devices is needed.}} | ||
{{hint|Remember to run a benchmark tool (such as glmark2-es2) to help check stability.}} | {{hint|Remember to run a benchmark tool (such as glmark2-es2) to help check stability.}} | ||
edits
