Difference between revisions of "PinePhone Pro"
→‎First time setup: Moved warning into fat text, wording
(→‎Installation instructions: style, wording, redundancy)
(→‎First time setup: Moved warning into fat text, wording)
Line 30: Line 30:
== First time setup ==
{{Hint|Do not insert an empty micro SIM adapter into the phone, as it will get stuck on the contact pins.}}
When shipped the battery is isolated from the mainboard contacts using a protective plastic tab, which is required to be removed before using the phone. The battery '''will not''' charge until it is removed and some of the device’s functionality may not function properly.
The PinePhone Pro's SIM slot only accepts a micro SIM, please do not insert a nano SIM without an adapter. The SIM card has to be placed in the lower slot, while the microSD has to be placed in the upper slot. Notice: Do not insert an empty micro SIM adapter into the phone, as it will get stuck on the contact pins. An adapter from a nano to a micro SIM is included in the box.
The PinePhone Pro's SIM slot only accepts a micro SIM, please '''do not insert an empty micro SIM adapter or a nano SIM''' without an adapter into the phone, as the adapter will get stuck on the contact pins and the loose nano SIM will short the device! The SIM card has to be placed in the lower slot, while the microSD has to be placed in the upper slot. An adapter from a nano to a micro SIM is included in the box.
# Carefully remove the back panel using the notch in the corner of the back cover without overbending it
# Remove the battery (if the battery is stuck in the device please check [[PinePhone_FAQ#The_battery_is_stuck_inside_the_phone|this]] paragraph for a fix)
# Peel off the clear plastic sticker below it, which isolates the charging contacts
# Reinsert the battery
Moderator
1,524
edits
Navigation menu
