Difference between revisions of "PinePhone Pro"
(→‎Installation instructions: added a note as per common observations)
Line 81: Line 81:
* Let the phone charge for multiple hours.
Note: If that didn't work, try to remove the battery and the USB cable and hold the power button for a few seconds, before retrying the procedure.
Note: If that didn't work, try to remove the battery and the USB cable and hold the power button for a few seconds and then insert the battery again, before retrying the procedure.
Moderator
1,524
edits
Navigation menu
