Difference between revisions of "PinePhone (Pro) Keyboard"
style
(→‎Keyboard layout: decreased picture size)
(style)
Line 5: Line 5:
== Getting started ==
[[File:Ppkb_description.png|thumb|upright=1.2|
1. Pogo pins<br>
Pogo pins<br>
2. Battery switch<br>
Battery switch<br>
3. USB-C]]
USB-C connector]]
The keyboard case works with both the PinePhone and PinePhone Pro and features a clam-shell design. It uses pogo pins located on the phone’s midsection and attaches by replacing the default back cover. When folded, the phone’s screen and the keyboard rest securely against each other. The hinge features a 180° design, which not only allows for two-hand typing on a surface but also for comfortable thumb-typing when fully extended. The etched keycaps can be easily relocated for alternate layouts such as AZERTY or QWERTZ. The keyboard case runs an [https://xff.cz/git/pinephone-keyboard/ open firmware], which means that anyone with the know-how can alter existing functions or add new ones. The bottom (keyboard) and top (phone) sections of the assembly are well-balanced thanks to the large, 6000mAh, internal battery capable of charging the PinePhone (Pro) during operation. The internal battery effectively triples the phone’s battery life. The internal keyboard battery can be manually toggled on/off and the keyboard’s battery charge level can be read in the supported OSes; the keyboard remains functional with the battery fully depleted.
Moderator
1,470
edits
Navigation menu
