1
edit
(moved paragraph up, fix) |
(→Pogo pins not making proper contact: Added link to photo of shim and replaced "here" in previous link with more verbose description for screen readers.) |
Line 35: | Line 35: | ||
* Apply '''slight''' pressure in the upper mid of the PinePhone's backside until the plastic holder pin towards the upper middle of the keyboard cover, until an audible click can be heard | * Apply '''slight''' pressure in the upper mid of the PinePhone's backside until the plastic holder pin towards the upper middle of the keyboard cover, until an audible click can be heard | ||
* If that solution does not work, a shim under the keyboard's contacts might be required, as explained [https://xnux.eu/pinephone-keyboard/faq.html#ts | * If that solution does not work, a shim under the keyboard's contacts might be required, as explained [https://xnux.eu/pinephone-keyboard/faq.html#ts FAQ troubleshooting section]. See also this [https://freiburg.social/system/media_attachments/files/107/684/243/421/870/279/original/a5e9c68ff3510ec8.jpeg photo of where to place the shim] | ||
==== Top row is less responsive ==== | ==== Top row is less responsive ==== |
edit
