Moderator
1,470
edits
(→Pogo pins not making proper contact: content) |
(moved paragraph up, fix) |
Line 28: | Line 28: | ||
=== Troubleshooting === | === Troubleshooting === | ||
{{Under construction}} | {{Under construction}} | ||
There are multiple possible issues user could face. It is recommend to check the following most common issues and their solutions and workarounds. | There are multiple possible issues user could face. It is recommend to check the following most common issues and their solutions and workarounds. <!-- === Missing support in the operating system === --> | ||
<!-- === Missing support in the operating system === --> | |||
==== Pogo pins not making proper contact ==== | ==== Pogo pins not making proper contact ==== | ||
Line 41: | Line 39: | ||
==== Top row is less responsive ==== | ==== Top row is less responsive ==== | ||
== Safety == | |||
{{Under construction}} | |||
{{warning|1=Do NOT plug any power source into the phone USB-C port while the keyboard is attached. Doing so may result in damage or loss of the keyboard charging functionality.}} | |||
{{warning|1=Do NOT lube the keyboard with GPL 205G0 switch grease. It can cause problems with the key responsiveness and tactility.}} | |||
{{hint|Only use mild isopropyl alcohol when wiping down the clamshell of the device. Stronger solutions may partially strip the coatings.}} | |||
== Software support == | == Software support == | ||
Line 109: | Line 113: | ||
* Charger input: 5V, 3A (15W) | * Charger input: 5V, 3A (15W) | ||
** Charging and battery IC chip: IP5209 power management IC with charge indicate controller and boost converter | ** Charging and battery IC chip: IP5209 power management IC with charge indicate controller and boost converter | ||
== Frequently asked questions == | == Frequently asked questions == |
