Moderator
1,479
edits
(Moved from the add-on article) |
Line 145: | Line 145: | ||
''' Can you open the keyboard and add extra functionality? '''<br> | ''' Can you open the keyboard and add extra functionality? '''<br> | ||
It is possible to do so, however the production units can be extremely difficult to open. Do not attempt to open the keyboard if you do not want to risk cosmetic damage (scaring and scratching of the plastic). | It is possible to do so, however the production units can be extremely difficult to open. Do not attempt to open the keyboard if you do not want to risk cosmetic damage (scaring and scratching of the plastic). | ||
== Document == | |||
* [https://files.pine64.org/doc/PinePhone/USER%20MANUAL-KEYBOARD-V2-EN-DE-FR-ES.pdf PinePhone Keyboard 4 language user manual ver 2.0 in PDF format] | |||
* [https://files.pine64.org/doc/PinePhone/USER%20MANUAL-KEYBOARD-V2-EN-DE-FR-ES.odt PinePhone Keyboard 4 language user manual ver 2.0 in ODT format] | |||
== Schematics, Datasheet and certifications == | |||
* Schematic: | |||
** [https://files.pine64.org/doc/PinePhone/PinePhone%20Keyboard%20Schematic%20V1.0-20211009.pdf PinePhone Keyboard Schematic ver 1.0 20211009] | |||
* Datasheet: | |||
** [https://files.pine64.org/doc/datasheet/pinephone/EM85F684A.pdf PEM85F684A USB Microcontroller Datasheet] | |||
** [https://files.pine64.org/doc/datasheet/pinephone/IP5209.pdf IP5209 Power Bank SOC Datasheet] | |||
** [https://files.pine64.org/doc/datasheet/pinephone/txs0104e.pdf TXS0104E 4-Bit Bidirectional Voltage-Level Translator Datasheet] | |||
* Certifications: | |||
** [https://files.pine64.org/doc/cert/PinePhone%20Keyboard%20FCC%20Certificate-S21111804102001.pdf PinePhone Keyboard FCC Certificate] | |||
** [https://files.pine64.org/doc/cert/PinePhone%20Keyboard%20CE%20Certificate-S21111804101001.pdf PinePhone Keyboard CE RED Certificate] | |||
== External links == | == External links == | ||
* [https://www.pine64.org/2022/01/11/pinephone-pro-explorer-edition-pre-orders-open-january-11/ Pre-order announcement] | * [https://www.pine64.org/2022/01/11/pinephone-pro-explorer-edition-pre-orders-open-january-11/ Pre-order announcement] | ||
* FAQ of the developer megous: https://xnux.eu/pinephone-keyboard/faq.html | * FAQ of the developer megous: https://xnux.eu/pinephone-keyboard/faq.html |
