360
edits
(→Safety) |
Line 100: | Line 100: | ||
== Safety == | == Safety == | ||
{{warning|1=Do NOT plug any power source into the phone USB-C port while the keyboard is attached. Doing so may result in damage or loss of the keyboard charging functionality}} | |||
{{warning|1=Do NOT lube the keyboard with GPL 205G0 switch grease. It can cause problems with the key responsiveness and tactility.}} | {{warning|1=Do NOT lube the keyboard with GPL 205G0 switch grease. It can cause problems with the key responsiveness and tactility.}} | ||
{{hint|Only use mild isopropyl alcohol when wiping down the clamshell of the device. Stronger solutions may partially strip the coatings.}} | {{hint|Only use mild isopropyl alcohol when wiping down the clamshell of the device. Stronger solutions may partially strip the coatings.}} |
edits
