Moderator
1,491
edits
(→Accessory: +link) |
(order) |
Line 1: | Line 1: | ||
The '''PinePhone''' and '''PinePhone Pro''' is compatible with a wide variety of accessories. A selection can be found here. | The '''PinePhone''' and '''PinePhone Pro''' is compatible with a wide variety of accessories. A selection can be found here. | ||
== | == Protection == | ||
=== Screen protector === | |||
The official screen protector can be found in the Pine64 store under [https://pine64.com/product/pinephone-tempered-glass-screen-protector/?v=0446c16e2e66 PinePhone Tempered Glass Screen Protector]. | |||
Most screen protectors for the iPhone 11 Pro Max, iPhone XS Max and Huawei Y7 (2018) fit the PinePhone if the top notch is not obscured by a black foil or a similar obstruction. | |||
=== Case === | |||
The Pine store has official cases: | |||
* [https://pine64.com/?product=pinephone-hard-protective-case&v=0446c16e2e66 PinePhone Hard Protective Case] | |||
* [https://pine64.com/?product=pinephone-soft-tpu-protective-case-reduce-digital-gap-donation-program&v=0446c16e2e66 PinePhone Soft TPU Protective Case - "Reduce Digital Gap" Donation Program] | |||
Tight-fit cases of other phones can't be used with the PinePhone because most times the proportions and/or camera notch won't fit. The phone can however be used with most "phone sleeves", such as those from fitBAG. The sleeve from fitBAG for the Xiaomi Redmi Note 8 Pro fits the PinePhone tightly. | |||
== Add-ons == | |||
The PinePhone and PinePhone Pro can be extended by replacing the default back cover with custom accessory connecting to the pogo pins on the phone's midsection. Currently the keyboard case, the fingerprint reader, the wireless charging case and the PineDio LoRa case is available. | The PinePhone and PinePhone Pro can be extended by replacing the default back cover with custom accessory connecting to the pogo pins on the phone's midsection. Currently the keyboard case, the fingerprint reader, the wireless charging case and the PineDio LoRa case is available. | ||
Line 35: | Line 49: | ||
The PineDio LoRa case can be found on the store: https://pine64.com/product/pinephone-pinephone-pro-pindio-lora-add-on-case/ | The PineDio LoRa case can be found on the store: https://pine64.com/product/pinephone-pinephone-pro-pindio-lora-add-on-case/ | ||
== Community-built accessory == | == Community-built accessory == |
