43
edits
Line 218: | Line 218: | ||
This command does not persist a reboot. | This command does not persist a reboot. | ||
=== Opening Pinetab === | |||
Be very careful here. It is not a 'pop off' cover design. | |||
Gently use fingernails, or (if you have one) a plastic pry, starting in the very middle of each side (saving keyboard connector area (bottom side) for last). | |||
Work your way from middle of each side, slowly towards the corners (saving actual corners themselves for the second to last)). The very last opening should be the "latch over" where the keyboard connects pins. | |||
== External Links == | == External Links == |
edits
