Difference between revisions of "Quartz64 Installing Arch Linux ARM"
Update linux-aarch64-rc package link to rc5
m (add categories)
(Update linux-aarch64-rc package link to rc5)
Line 112: Line 112:
{{note|Here's where you'd do the part I said was iffy and won't be necessary with 5.16 anymore. You'll need an Arch Linux or Manjaro system. If it's not an aarch64 system, you'll also need <tt>qemu-user-static</tt>.
First, get [https://overviewer.org/~pillow/up/e96363af01/linux-aarch64-rc-5.16.rc4-1-aarch64.pkg.tar.zst the linux-aarch64-rc package I patched and built], then copy it somewhere into your mounted root.
First, get [https://overviewer.org/~pillow/up/04425c6141/linux-aarch64-rc-5.16.rc5-1-aarch64.pkg.tar.zst the linux-aarch64-rc package I patched and built], then copy it somewhere into your mounted root.
Alternatively, patch and build the package yourself by [https://github.com/archlinuxarm/PKGBUILDs/tree/master/core/linux-aarch64-rc getting the package sources] and [https://gist.github.com/CounterPillow/310273c9632f25c436fb4fdfa0128068 patching the package (in this case also for cross-compilation)].
Line 122: Line 122:
and install the package
<code># pacman -U linux-aarch64-rc-5.16.rc4-1-aarch64.pkg.tar.zst</code>
<code># pacman -U linux-aarch64-rc-5.16.rc5-1-aarch64.pkg.tar.zst</code>
Then <code>exit</code> the chroot again once it's done installing.
493
edits
Navigation menu
