Difference between revisions of "Quartz64 Installing Arch Linux ARM"
m
add categories
m (Using 'unit X' is only needed when you don't specify a unit, so add a unit to the only one which hadn't and remove 'unit X')
m (add categories)
Line 142: Line 142:
You are now ready to use Arch Linux ARM! Either delete or rename (and move the homedir of) the <code>alarm</code> user, and you're all set. Don't forget to install things like <code>sudo</code> and setting up sudo groups and such.
[[Category:Quartz64]] [[Category:Guide]] [[Category:Quartz64 Guides]]
504
edits
Navigation menu
