13
edits
(Add instructions for packaging the thing yourself due to the current scare) |
m (Using 'unit X' is only needed when you don't specify a unit, so add a unit to the only one which hadn't and remove 'unit X') |
Line 13: | Line 13: | ||
Create the partitions for loader and u-boot: | Create the partitions for loader and u-boot: | ||
# parted -s /dev/sdb | # parted -s /dev/sdb mkpart loader 64s 8MiB | ||
# parted -s /dev/sdb | # parted -s /dev/sdb mkpart uboot 8MiB 16MiB | ||
Create the partition for u-boot's environment: | Create the partition for u-boot's environment: | ||
# parted -s /dev/sdb | # parted -s /dev/sdb mkpart env 16MiB 32MiB | ||
Create the "efi" boot partition and mark it as bootable: | Create the "efi" boot partition and mark it as bootable: | ||
# parted -s /dev/sdb | # parted -s /dev/sdb mkpart efi fat32 32MiB 544MiB | ||
# parted -s /dev/sdb set 4 boot on | # parted -s /dev/sdb set 4 boot on | ||
Create the root partition: | Create the root partition: | ||
# parted -s /dev/sdb | # parted -s /dev/sdb mkpart root ext4 544MiB 100% | ||
=== Creating The File Systems === | === Creating The File Systems === |
edits
