492
edits
m (CounterPillow moved page Installing Arch Linux ARM On The Quartz64 to Quartz64 Installing Arch Linux ARM) |
(Add instructions for packaging the thing yourself due to the current scare) |
Line 110: | Line 110: | ||
=== Finishing Touches === | === Finishing Touches === | ||
{{note|Here's where you'd do the part I said was iffy and won't be necessary with 5.16 anymore. You'll need an Arch Linux or Manjaro system. If it's not an aarch64 system, you'll also need <tt>qemu-user-static</tt>. First, get [https://overviewer.org/~pillow/up/e96363af01/linux-aarch64-rc-5.16.rc4-1-aarch64.pkg.tar.zst the linux-aarch64-rc package I patched and built], then copy it somewhere into your mounted root. | {{note|Here's where you'd do the part I said was iffy and won't be necessary with 5.16 anymore. You'll need an Arch Linux or Manjaro system. If it's not an aarch64 system, you'll also need <tt>qemu-user-static</tt>. | ||
First, get [https://overviewer.org/~pillow/up/e96363af01/linux-aarch64-rc-5.16.rc4-1-aarch64.pkg.tar.zst the linux-aarch64-rc package I patched and built], then copy it somewhere into your mounted root. | |||
Alternatively, patch and build the package yourself by [https://github.com/archlinuxarm/PKGBUILDs/tree/master/core/linux-aarch64-rc getting the package sources] and [https://gist.github.com/CounterPillow/310273c9632f25c436fb4fdfa0128068 patching the package (in this case also for cross-compilation)]. | |||
Next, <code>arch-chroot</code> into the mounted root: | Next, <code>arch-chroot</code> into the mounted root: |
edits
