493
edits
m |
Line 1: | Line 1: | ||
{{note|This page is a work in progress. It's not a tutorial you can follow yet. Wait for the 5.16 kernel release. Right now there's still an | {{note|This page is a work in progress. It's not a tutorial you can follow yet. Wait for the 5.16 kernel release. Right now there's still an iffy step left: installing a custom kernel package to get it booting. This will no longer be necessary with Linux 5.16.}} | ||
Commands to be run as a normal user are prefixed with <code>$</code>, commands to be run as root are prefixed with <code>#</code>. We assume your target device is <tt>/dev/sdb</tt>, adjust accordingly. | Commands to be run as a normal user are prefixed with <code>$</code>, commands to be run as root are prefixed with <code>#</code>. We assume your target device is <tt>/dev/sdb</tt>, adjust accordingly. | ||
Line 108: | Line 108: | ||
For a different type of Quartz64 device (e.g. Model B) replace the <tt>fdt</tt> line with the appropriate <tt>/boot</tt>-relative path to the device tree. | For a different type of Quartz64 device (e.g. Model B) replace the <tt>fdt</tt> line with the appropriate <tt>/boot</tt>-relative path to the device tree. | ||
{{note|Here's where you'd do the part I said was | {{note|Here's where you'd do the part I said was iffy and won't be necessary with 5.16 anymore. You'll need an Arch Linux or Manjaro system. If it's not an aarch64 system, you'll also need <tt>qemu-user-static</tt>. First, get [https://overviewer.org/~pillow/up/e96363af01/linux-aarch64-rc-5.16.rc4-1-aarch64.pkg.tar.zst the linux-aarch64-rc package I patched and built], then copy it somewhere into your mounted root. | ||
Next, <code>arch-chroot</code> into the mounted root: | Next, <code>arch-chroot</code> into the mounted root: |
edits
