Difference between revisions of "Quartz64 Installing Arch Linux ARM"
done
(done)
Line 1: Line 1:
{{note|This page is a work in progress. It's not a tutorial you can follow yet. Wait for the 5.16 kernel release.}}
{{note|This page is a work in progress. It's not a tutorial you can follow yet. Wait for the 5.16 kernel release. Right now there's still an undocumented step left: installing a custom kernel package to get it booting. This will no longer be necessary with Linux 5.16.}}
Commands to be run as a normal user are prefixed with <code>$</code>, commands to be run as root are prefixed with <code>#</code>. We assume your target device is <tt>/dev/sdb</tt>, adjust accordingly.
Line 115: Line 115:
  # umount /mnt/alarm-root/boot
== Booting And Finishing Setup ==
Hook up your UART dongle to your Quartz64, open a serial terminal at 1.5mbauds. Install the SD card or eMMC module inside the Quartz64, and plug in the power.
Once you hit a login shell, log in as <code>root</code> with password <code>root</code> and run:
# pacman-key --init
# pacman-key --populate archlinuxarm
You are now ready to use Arch Linux ARM! Either delete or rename (and move the homedir of) the <code>alarm</code> user, and you're all set. Don't forget to install things like <code>sudo</code> and setting up sudo groups and such.
504
edits
Navigation menu
