501
edits
m |
(found the key after all.) |
Line 13: | Line 13: | ||
== Fetching The Root File System Tarball == | == Fetching The Root File System Tarball == | ||
Fetch the root filesystem tarball over HTTPS from the de3 mirror, the autoselect mirror is broken and will sometimes feed you mirrors with broken HTTPS | Fetch the root filesystem tarball over HTTPS from the de3 mirror, the autoselect mirror is broken and will sometimes feed you mirrors with broken HTTPS. | ||
$ wget -N https://de3.mirror.archlinuxarm.org/os/ArchLinuxARM-aarch64-latest.tar.gz{,. | $ wget -N https://de3.mirror.archlinuxarm.org/os/ArchLinuxARM-aarch64-latest.tar.gz{,.sig} | ||
Fetch the gpg keys: | |||
$ | $ curl 'https://keyserver.ubuntu.com/pks/lookup?op=get&search=0x68b3537f39a313b3e574d06777193f152bdbe6a6' | gpg --import=- | ||
Verify the tarball's authenticity | |||
$ gpg --verify ArchLinuxARM-aarch64-latest.tar.gz.sig | |||
== Installing The Root File System == | == Installing The Root File System == |
edits
