501
edits
(work in progress installation instructions for Arch Linux ARM on Quartz64) |
m |
Line 15: | Line 15: | ||
Fetch the root filesystem tarball over HTTPS from the de3 mirror, the autoselect mirror is broken and will sometimes feed you mirrors with broken HTTPS, and you can't get the GPG keys to verify the tarball anywhere. | Fetch the root filesystem tarball over HTTPS from the de3 mirror, the autoselect mirror is broken and will sometimes feed you mirrors with broken HTTPS, and you can't get the GPG keys to verify the tarball anywhere. | ||
$ wget https://de3.mirror.archlinuxarm.org/os/ArchLinuxARM-aarch64-latest.tar.gz{,.md5} | $ wget -N https://de3.mirror.archlinuxarm.org/os/ArchLinuxARM-aarch64-latest.tar.gz{,.md5} | ||
Verify that the file survived the transfer (i.e. the connection didn't get interrupted prematurely). This provides no security against maliciously modified tarballs, just aborted transfers: | Verify that the file survived the transfer (i.e. the connection didn't get interrupted prematurely). This provides no security against maliciously modified tarballs, just aborted transfers: | ||
Line 51: | Line 51: | ||
prompt 0 | prompt 0 | ||
timeout 50 | timeout 50 | ||
label l0 | label l0 | ||
menu label Boot Arch Kernel SDMMC | menu label Boot Arch Kernel SDMMC |
edits
