5
edits
(→Disassembly and Reassembly: added display/top lid disassembly information.) |
(→Disassembly and Reassembly: applying proofreads from dsimic @ irc.) |
Line 876: | Line 876: | ||
[[File:Standoffs.png|400px|thumb|right|Pinebook Screw stand-offs correct placement and location]] | [[File:Standoffs.png|400px|thumb|right|Pinebook Screw stand-offs correct placement and location]] | ||
[[File:Hinges_cover_removed_1.jpeg|300px|thumb|right|Pinebook Pro | [[File:Hinges_cover_removed_1.jpeg|300px|thumb|right|Hinge area of the Pinebook Pro lid with the cover removed]] | ||
[[File:Hinges_cover_removed_2.jpeg|300px|thumb|right|Pinebook Pro | [[File:Hinges_cover_removed_2.jpeg|300px|thumb|right|Close-up of a Pinebook Pro lid hinge]] | ||
There are a few '''mandatory''' precautions to be taken: | There are a few '''mandatory''' precautions to be taken: | ||
Line 895: | Line 895: | ||
A basic 3D model to print replacement standoffs for the back cover screws is [https://www.thingiverse.com/thing:4226648 available on Thingiverse], until the official drawings or 3D models are made available. | A basic 3D model to print replacement standoffs for the back cover screws is [https://www.thingiverse.com/thing:4226648 available on Thingiverse], until the official drawings or 3D models are made available. | ||
====Display Disassembly==== | |||
It is not recommended to adjust the position of the lid when the bottom cover is removed, because the bottom cover provides structural strength, so the lid should be open fully as the first step, before starting any disassembly of the laptop. After opening the lid, remove the bottom cover by following the instruction found in the section above. Alternatively, you can keep the lid closed and remove the screws that hold the hinges to the main laptop body, as described in [[Pinebook Service Step by Step Guides]]. | |||
Parts of the hinge mechanism, as well as the screws that hold the hinges to the lid, are hidden behind an elongated plactic U-shaped cover that snaps in place using latches. Use a dedicated plastic prying tool or a guitar pick to gently pry the cover and remove it, starting from the outer edge. Once you pry the cover to a certain extent, it should be possible to remove it fully using only your hands. The U-shaped cover is rather sturdy, but still be careful not to break or bend it. | |||
There are two small screws hidden underneath the two small rubber nubs on the upper part of the screen bezel, so first gently remove the nubs and then remove the screws. The screen bezel is held in place with a combination of latches and some adhesive tape, which is there to prevent dust ingress. The adhesive isn't very strong, and the bezel is capable of flexing back into shape after being twisted to a certain extent. There is more adhesive on the bottom part of the screen bezel, so be more careful while prying that section apart. Use the same prying tool that you used for the U-shaped cover, and work it around the outer edges of the screen bezel. | |||
== Internal Layout == | == Internal Layout == |
edits
