131
edits
(Add more technical notes) |
(Fix the new line problem, thanks fxc for point ths out, and https://stackoverflow.com/questions/686898) |
Line 1: | Line 1: | ||
<noinclude> | <noinclude> | ||
{{Template}} | {{Template}} | ||
Line 12: | Line 11: | ||
<nowiki>{{Note|This is an note.}}</nowiki> | <nowiki>{{Note|This is an note.}}</nowiki> | ||
{{Note | This is an note.}} | {{Note | This is an note.}} | ||
For a more flexible usage, it doesn't start with "'''Note:'''" by default, | For a more flexible usage, it doesn't start with "'''Note:'''" by default, | ||
you may add it manually with <code><nowiki>'''Note:'''</nowiki></code>: | you may add it manually with <code><nowiki>'''Note:'''</nowiki></code>: | ||
<nowiki>{{Note|'''Note:''' This is an note.}}</nowiki> | <nowiki>{{Note|'''Note:''' This is an note.}}</nowiki> | ||
{{Note | '''Note:''' This is an note.}} | {{Note | '''Note:''' This is an note.}} | ||
== Technical notes == | == Technical notes == | ||
Line 35: | Line 34: | ||
* [[Template:Hint]] | * [[Template:Hint]] | ||
* [[Template:Warning]] | * [[Template:Warning]] | ||
</noinclude><includeonly><div role="note" class="template-box template-hint" style=" | |||
</noinclude><includeonly> | |||
display: table; | display: table; | ||
min-width: 16em; | min-width: 16em; | ||
Line 47: | Line 43: | ||
color: #705000; | color: #705000; | ||
background-color: #fef6e7; | background-color: #fef6e7; | ||
">{{{1|}}}</div> | ">{{{1|}}}</div></includeonly> | ||
</includeonly> |
edits
