Difference between revisions of "Template:Note"
295 bytes added ,  09:04, 22 September 2021
Enhance Example
(Refactor)
(Enhance Example)
Line 3: Line 3:
{{Template}}
{{Template}}
A note box for showing important notes.
== Usage ==
== Usage ==
  <nowiki>{{Note|This is an note.}}</nowiki>
  <nowiki>{{Note|note content}}</nowiki>
== Example ==
== Examples ==
{{Note | This is an note.}}
For a more flexible usage, it doesn't start with "'''Note:'''" by default,
you may add it manually with <code><nowiki>'''Note:'''</nowiki></code>:
<nowiki>{{Note|'''Note:''' This is an note.}}</nowiki>
{{Note | '''Note:''' This is an note.}}
== Technical notes ==
This template uses class <code>.template-box</code> and <code>.template-note</code> to make the output HTML more parsable.
This template uses class <code>.template-box</code> and <code>.template-note</code>.
In the future, if the [https://www.mediawiki.org/wiki/Extension:TemplateStyles TemplateStyles Extension] is installed on this MediaWiki instance,
one may move the embedded inline styles to Template Style files.
131
edits
Navigation menu
