130
edits
(→Manjaro ARM: Remove empty lines) |
m (→Multi-distro demo image: Remove empty lines) |
Line 321: | Line 321: | ||
** '''File Size:''' 6.8GB | ** '''File Size:''' 6.8GB | ||
Due to its size, download though torrent is suggested by the author on its main page. | Due to its size, download though torrent is suggested by the author on its main page.<!-- | ||
{{hint | '''Note about .zst archive file:''' | -->{{hint | '''Note about .zst archive file:''' | ||
On Linux, you may install or compile <code>zstd</code>, and write the image to SD card by using <code>zstdcat</code> and <code>dd</code>. See the "Installation" section of its [https://xnux.eu/p-boot-demo/ web page] for command examples. | On Linux, you may install or compile <code>zstd</code>, and write the image to SD card by using <code>zstdcat</code> and <code>dd</code>. See the "Installation" section of its [https://xnux.eu/p-boot-demo/ web page] for command examples. | ||
On Windows, you may use [https://github.com/mcmilk/7-Zip-zstd 7-zip-zstd], it provides different installation method in the README.md. Install and extract the .img file from the zst archive, and flash with tools like [https://sourceforge.net/projects/win32diskimager/ Win32 Disk Imager]. | On Windows, you may use [https://github.com/mcmilk/7-Zip-zstd 7-zip-zstd], it provides different installation method in the README.md.Install and extract the .img file from the zst archive, and flash with tools like [https://sourceforge.net/projects/win32diskimager/ Win32 Disk Imager].}}<!-- | ||
-->Also see [[PinePhone Installation Instructions]]. | |||
'''username/password''' | '''username/password''' |
edits
