130
edits
m (→Installing other ARM64 distributions: add link to the README of megi's kernel, adjust content) |
m (→Gentoo: Remove empty lines) |
Line 100: | Line 100: | ||
== Gentoo == | == Gentoo == | ||
[[File:GentooLogo.png|right|100px]] | [[File:GentooLogo.png|right|100px]]<!-- | ||
{{hint|Please consider cross-compiling the software on the computer. | -->{{hint|Please consider cross-compiling the software on the computer. | ||
Long compilation times and heat production can lead to a reduced lifespan of the phone.}} | Long compilation times and heat production can lead to a reduced lifespan of the phone.}}<!-- | ||
There are unofficial Gentoo overlays with ebuilds for the PinePhone. | -->There are unofficial Gentoo overlays with ebuilds for the PinePhone. | ||
There are no images - you'll be building it yourself, picking which kernel, bootloader and desktop environment you want to use. | There are no images - you'll be building it yourself, picking which kernel, bootloader and desktop environment you want to use. | ||
You will be using the arm64 version of Gentoo. | You will be using the arm64 version of Gentoo. |
edits
