35
edits
m (→Maemo Leste: typo) |
AntMan 1300 (talk | contribs) Tags: Mobile web edit Mobile edit |
Line 627: | Line 627: | ||
General step: | General step: | ||
# Create a boot (from 4 MB to about 252 MB) and root (from the end of boot to the end of the card) filesystem on the SD card. | # Create a boot partition (from 4 MB to about 252 MB) and a root partition (from the end of boot to the end of the card) filesystem on the SD card. | ||
# Format the boot partition with vfat, and the root partition with a supported filesystem like ext4 or f2fs. | # Format the boot partition with vfat, and the root partition with a supported filesystem like ext4 or f2fs. | ||
# Extract the root filesystem from your distribution's ARM image into the root filesystem on the SD card. Do not copy the partition, copy the files (in archive mode: like <code>rsync -ar</code>). | # Extract the root filesystem from your distribution's ARM image into the root filesystem on the SD card. Do not copy the partition, copy the files (in archive mode: like <code>rsync -ar</code>). |
edits
