Difference between revisions of "Overclocking"
9 bytes removed ,  00:35, 6 September 2021
Line 72: Line 72:
{{note|I'm (33yn2) not particularly sure if this makes any difference, or if it might infact have a negative impact. Probably not worth messing with.}}
= Rockchip RK3399 based boards =
= RK3399-based devices =
The RK3399 clocks are found in [https://github.com/torvalds/linux/blob/master/arch/arm64/boot/dts/rockchip/rk3399-opp.dtsi arch/arm64/boot/dts/rockchip/rk3399-opp.dtsi]
Line 99: Line 99:
The stock speed for the little cores is 1.4GHz and on the big cores it is 1.8GHz, however the OP1 speeds default to 1.5GHz and 2.0GHz instead.
= ROCK64 =
= ROCK64 =
360
edits
Navigation menu
