Difference between revisions of "PINE H64"
6 bytes removed ,  15:29, 4 September 2021
m
(typo)
m (→‎Android: typos)
Line 153: Line 153:
[[File:android_9.png|right|100px]]
===== Stock Android 9.0 microSD Card to eMMC 20190523] =====
===== Stock Android 9.0 microSD Card to eMMC 20190523 =====
* DD image to microSD card, install eMMC module, plug in microSD card into slot and boot.
** After power ON the box for 2-3 second, it will start writing the new image to the eMMC with progress bar. Once finished upload to eMMC, take out microSD card and reboot.
Line 167: Line 167:
**** File Size: 1.21GB
===== Stock Android 9.0 microSD and eMMC Boot 20190523] =====
===== Stock Android 9.0 microSD and eMMC Boot 20190523 =====
* Support 4K HDR playeback
* Highly recommend using [https://etcher.io/ Etcher]
Line 191: Line 191:
**** File Size: 1.02GB
===== Stock Android 9.0 Phoenix Card image 20190523] =====
===== Stock Android 9.0 Phoenix Card image 20190523 =====
* Only use Phoenixcard method as last resort option
*** [https://files.pine64.org/os/pine-h64/android/PhoenixCard4_1_3.zip Phoenixcard ver 4.1.3 utility direct download from pine64.org]
Line 208: Line 208:
[[File:android_7.png|right|100px]]
===== Stock Android 7.0 microSD Card Boot 20190115] =====
===== Stock Android 7.0 microSD Card Boot 20190115 =====
Line 230: Line 230:
**** File Size: 482MB
===== Stock Android 7.0 microSD Card to eMMC 20190115] =====
===== Stock Android 7.0 microSD Card to eMMC 20190115 =====
* DD image to microSD card, install eMMC module, plug in muicroSD vard into slot and boot.
Line 242: Line 242:
**** File Size: 414MB
===== Stock Android 7.0 Phoenix Card image 20190115] =====
===== Stock Android 7.0 Phoenix Card image 20190115 =====
Moderator
1,522
edits
Navigation menu
