Difference between revisions of "PineNote"
22 bytes added ,  03:55, 20 August 2021
no edit summary
Line 135: Line 135:
* '''Where is the microSD card slot?''' The case design of the PineNote is fixed, making physical changes like adding a microSD card slot would raise the cost unreasonably. However, revisions of the PineNote motherboard after 1.1 will feature an internal ribbon cable connector where a microSD card slot may be attached. Attaching such a device will require taking the PineNote apart.
* '''How will I install software to the PineNote?''' This is a hardware and software question. If the software on your PineNote is completely broken and cannot boot to a recoverable state, a Hall (magnet) sensor was fitted to the PineTab motherboard as U9009. This sensor is attached to SARADC_VIN0_KEY/RECOVERY on the RK3566. With the device powered off, holding a magnet over U9009 and plugging in a USB-C cable causes the device to boot into [http://opensource.rock-chips.com/wiki_Rockusb|"rockusb"] flash mode. With proper flashing software and drivers, it should be possible to load a new operating system using rockusb if the system is soft-bricked. Of course, software vendors will need to be more careful with flashing firmware and providing useful "recovery" options on this device due to this process's relative difficulty to other PINE64 devices.
==== Unresolved ====
The following concerns have been brought up as open, unanswered topics:
Navigation menu
