Difference between revisions of "Pinebook Pro Software Release"
→‎Arch Linux ARM: The previous repositories are retired. Links updated to new repositories.
(→‎Arch Linux ARM: The previous repositories are retired. Links updated to new repositories.)
Line 154: Line 154:
[[File:Archlinux-logo.png|right|100px]]
Arch ARM image customized for Arch Linux ARM on the Pinebook Pro. It boots from microSD card and from eMMC.
Arch Linux ARM root filesystem customized for the Pinebook Pro. Instructions are included for installation on microSD card, eMMC module and NVME SSD.
'''Download location'''
Get the latest image here: [https://github.com/nadiaholmquist/archiso-pbp/releases Direct download for latest releases from GitHub] (size: 579 MB)
[https://github.com/SvenKiljan/archlinuxarm-pbp/releases/latest Get the latest image from GitHub] (size: 591 MB).
'''Installation'''
'''Installation'''
Make sure to thoroughly read the [https://github.com/nadiaholmquist/archiso-pbp/blob/master/README.md readme] and [https://github.com/nadiaholmquist/archiso-pbp/blob/master/FAQ.md FAQ], otherwise follow the normal Arch installation guide.
Make sure to thoroughly read the [https://github.com/SvenKiljan/archlinuxarm-pbp/blob/main/README.md readme], [https://github.com/SvenKiljan/archlinuxarm-pbp/blob/main/README.md installation instructions] and [https://github.com/SvenKiljan/archlinuxarm-pbp/blob/main/FAQ.md FAQ].
'''Username and password'''
Automatic login as root
The default Arch Linux ARM user credentials.
Username: alarm
Password: alarm
The password for the root account is 'root'.
== postmarketOS ==
== postmarketOS ==
1
edit
Navigation menu
