Difference between revisions of "Guide:Locating your device"
Line 2: Line 2:
==Locating your device==
Forum link: [https://forum.pine64.org/showthread.php?tid=4868&pid=30165#pid30165 Finding out the IP address of your Rock64 Board when its not connected to a display (Headless) ]
In this guide, you will be shown one way to find your network connected ROCK64 board, if you do not have it connected to any display devices. This is useful if you're using it as a server, or simply if you wish to access it and you dont have a spare keyboard/display.
Line 85: Line 88:
Note down the IP and MAC address. Depending on your Router (and DHCP) configuration, rebooting your Rock 64 board or your Router might result in the IP address of the Rock 64 Changing. However, the MAC address should stay the same. Simply do a scan using the app to find the IP address of your board if you suspect the IP address has changed.
'''References'''
Navigation menu
