Difference between revisions of "Guide:Setting up an SMB (Windows) file server"
m
category, formatting, typos
(added category)
m (category, formatting, typos)
Line 1: Line 1:
== Preface ==
== Preface ==
This guide will show you how to share a directory using the SMB (windows file sharing)protocol to allow other clients to connect to it and share files amongst one another. I will also show how to make the share accessible by predefined users with passwords, or accessible to anybody.
This guide will show you how to share a directory using the SMB (windows file sharing) protocol to allow other clients to connect to it and share files amongst one another. I will also show how to make the share accessible by predefined users with passwords, or accessible to anybody.
There are many guides already detailing the exact same thing, why post a new one?
Line 7: Line 7:
* Some use really old versions of the samba service and share definitions
* Others gloss over or skip file/directory permissions, resulting in "read only" shares and other such frustrations
* Quite a few poor practises (EG: using sudo $EDITOR $FILE, instead of sudoedit). [https://superuser.com/questions/785187/sudoedit-why-use-it-over-sudo-vi Why that is good practise is detailed here.]
* Quite a few poor practices (EG: using sudo $EDITOR $FILE, instead of sudoedit). [https://superuser.com/questions/785187/sudoedit-why-use-it-over-sudo-vi Why that is good practice is detailed here.]
== Prerequisites ==
== Prerequisites ==
ROCK64 board running [http://wiki.pine64.org/index.php/ROCK64_Main_Page#ROCK64_Software_Images Debian or Ubuntu]
Access to terminal, either locally or via [http://wiki.pine64.org/index.php/Guide-_Connecting_to_your_device_with_SSH SSH]
Access to terminal, either locally or via [[Guide:Connecting_to_your_device_with_SSH|SSH]]
Some basic understanding of using the linux terminal: [https://www.howtogeek.com/140679/beginner-geek-how-to-start-using-the-linux-terminal/ Howtogeek]
Suggested: A basic comprehension of [http://wiki.pine64.org/index.php/Guide-_Adding_USB_storage_to_your_Device_and_Formatting_it_for_linux linux file permissions]
Suggested: A basic comprehension of [[Guide:Adding_USB_storage_to_your_Device_and_Formatting_it_for_linux|linux file permissions]]
Suggested: A USB storage device to host the shared directory on (to avoid filling up the System Partition)
This guide will start off from the directory created in a [http://wiki.pine64.org/index.php/Guide-_Adding_USB_storage_to_your_Device_and_Formatting_it_for_linux prior guide]. You dont '''need''' to have the network share hosted on a USB drive, you can host it anywhere really, I just prefer hosting on this way to avoid filling up the boot partition.
This guide will start off from the directory created in a [[Guide:Adding_USB_storage_to_your_Device_and_Formatting_it_for_linux|prior guide]]. You don't <i>need</i> to have the network share hosted on a USB drive, you can host it anywhere really, I just prefer hosting on this way to avoid filling up the boot partition.
Firstly, you'll need to update your repositories and install any pending updates. This is good practise before installing software on any linux system. [https://www.linux.com/learn/linux-101-updating-your-system Debian/Ubuntu use the "apt" package management tool]. You'll need superuser access for this.
== Guide ==
Firstly, you'll need to update your repositories and install any pending updates. This is good practice before installing software on any linux system. [https://www.linux.com/learn/linux-101-updating-your-system Debian/Ubuntu use the "apt" package management tool]. You'll need superuser access for this.
<tt>
<code>sudo apt update && sudo apt upgrade </code>
sudo apt update && sudo apt upgrade </tt>
Type in your password when prompted and '''y''' when prompted to install updates.
Line 31: Line 31:
After that, you'll need to invoke '''apt''' to install the samba server:
<tt>
<code>sudo apt install samba samba-common-bin</code>
sudo apt install samba samba-common-bin</tt>
[[File:Samba_apt_1.png|800px]]
[[File:Samba_apt_1.png|400px]]
Depending on your distro, '''samba-common-bin''' may already be installed. However, allow the other supporting software to be installed.
The next step is to create a directory to host the network share. In this senario, I will be placing it in the Flash drive mentioned in [http://wiki.pine64.org/index.php/Guide-_Adding_USB_storage_to_your_Device_and_Formatting_it_for_linux this tutorial].
The next step is to create a directory to host the network share. In this scenario, I will be placing it in the Flash drive mentioned in [[Guide:Adding_USB_storage_to_your_Device_and_Formatting_it_for_linux|this tutorial]].
Navigate to your mounted location. Following the linked tutorial, for me it is:
<tt>
<code>cd /media/USB-test3/</code>
cd /media/USB-test3/</tt>
Make a new directory which will act as the shared location. We will create it with Use/Write/Execute permissions for everybody inside the folder:
<tt>
<code>sudo mkdir -m 1777 RockShare</code>
sudo mkdir -m 1777 RockShare</tt>
Now we can edit Samba's configuration file to create a new share based on the directory we just set up:
<tt>
<code>sudoedit /etc/samba/smb.conf</code>
sudoedit /etc/samba/smb.conf</tt>
[[File:Smb.conf_1.png|800px]]
[[File:Smb.conf_1.png|400px]]
Use the '''Up/Down''' or '''PageUp/Down''' keys to navigate to the bottom of the file to create a new entry.
Line 69: Line 65:
  directory mask = 0777
  Public = yes
  Public = yes
  Guest ok = yes</tt>
  Guest ok = yes
</tt>
It should look somewhat similar to this after you've done editing it:
[[File:Smb.conf_2.png|800px]]
[[File:Smb.conf_2.png|400px]]
These options means that anybody can read, write or execute files in the share, either with a samba user or as a guest. To forbid guest access, simply omit the "guest ok" line. The title, in the square brackets, will be the name of the shared directory.
Line 81: Line 78:
First of all, you need to make a new linux user. In this case, I will be making a new user "'''rocksmb'''":
<tt>
<code>sudo useradd rocksmb</code>
sudo useradd rocksmb</tt>
After that, you can create a new samba user, and you'll be prompted to type in a password too. This is a unique password, independent to your linux user password:
<tt>
<tt>
sudo smbpasswd -a rocksmb
  New SMB password:
  New SMB password:
  Retype new SMB password:
  Added user rocksmb.</tt>
  Added user rocksmb.
</tt>
Now you restart the samba service:
Line 98: Line 95:
  [ ok ] Restarting nmbd (via systemctl): nmbd.service.
  [ ok ] Restarting smbd (via systemctl): smbd.service.
  [ ok ] Restarting samba-ad-dc (via systemctl): samba-ad-dc.service.</tt>
</tt>
Now your Samba share will be visible and accessible!
Line 104: Line 102:
If you wish to add more users, you simply repeat the steps mentioned above: Create a linux user, then a samba user and password.
You can also experiment with the above samba template, give predefined users different and unique folders if you wish, for example.
== Clients ==
=== Windows ===
There are many guides about how to access smb shares using '''Windows''':
Line 110: Line 111:
* https://www.linux.com/news/using-samba-share-files-between-linux-and-windows
== Mac OS ==
=== Mac OS ===
* https://support.apple.com/en-au/HT204445
== Ubuntu ==
=== Ubuntu ===
* https://help.ubuntu.com/stable/ubuntu-help/nautilus-connect.html
In all cases, replace the [http://wiki.pine64.org/index.php/Guide-_Setting_up_a_Hostname hostname]/[ http://wiki.pine64.org/index.php/Guide-Locating_your_device IP] in the guide with the ones you have.
In all cases, replace the [[Guide:Setting_up_a_Hostname|hostname]]/[[Guide:Locating_your_device|IP]] in the guide with the ones you have.
=== Mobile ===
If you want to access the drive using mobile apps, there are many apps available on both Android and iOS.
==== iOS ====
iOS: https://itunes.apple.com/us/app/fileexplorer-file-manager-for-computer-and-nas/id510282524?mt=8
==== Android ====
Android: https://play.google.com/store/apps/details?id=com.google.android.sambadocumentsprovider&hl=en
I dont have an iphone, so I'll do a quick rundown using the '''android''' app:
I don't have an iphone, so I'll do a quick rundown using the '''android''' app:
Download it and upen it to be greeted to a very simple credential screen. Simply fill in the details like:
Download it and open it to be greeted to a very simple credential screen. Simply fill in the details like:
<tt>
<code>smb://HOSTNAMEORIP/SHARE</code>
smb://HOSTNAMEORIP/SHARE</tt>
In our case:
In our case:
[[File:AndroidSMB_1.png|800px]]
[[File:AndroidSMB_1.png|100px]]
Assuming you've put in the right credentials, it will immediately open up the share using the default android file selector:
[[File:AndroidSMB_2.png|800px]]
[[File:AndroidSMB_2.png|100px]]
However Google's app is VERY rudimentary and barebones. I was able to open image files, but video and audio files gave me problems unless I copied them to internal memory.
Line 148: Line 151:
* Forum link: https://forum.pine64.org/showthread.php?tid=4983
[[Category:Rock64]]
[[Category:Rock64]][[Category:Guide]]
118
edits
Navigation menu
