42
edits
(→Reset: Wiki style) |
(5 intermediate revisions by 2 users not shown) | |||
Line 141: | Line 141: | ||
=== Manjaro ARM === | === Manjaro ARM === | ||
[[File:Manjaro-logo.svg|100px]] | [[File:Manjaro-logo.svg|100px]] | ||
The PineTab "Early Adopter" edition is currently | The PineTab "Early Adopter" edition is currently the only device supported by Manjaro ARM. | ||
Images with several different environments, including Phosh and Plasma, are available for the "Dev" pre-release can be downloaded [https://osdn.net/projects/manjaro-arm/storage/pinetab/ here] | |||
Images for the Early Adopter version can be downloaded [https://github.com/manjaro-arm/pinetab-images/releases here]. | |||
Both Beta releases and weekly unstable builds for Phosh and Plasma Mobile can be found there. | |||
=== Mobian === | === Mobian === | ||
Line 204: | Line 207: | ||
If your PineTab is in unknown state or doesn't want to start: Press power button for 7-8s. It makes a sound and you know it's totally off. 3 seconds after, power button again for 2-3s and it will start to boot. | If your PineTab is in unknown state or doesn't want to start: Press power button for 7-8s. It makes a sound and you know it's totally off. 3 seconds after, power button again for 2-3s and it will start to boot. | ||
=== Power Off While Charging === | |||
When plugging your Pinetab into a charger, it automatically powers on. Use the above "Reset" instruction (holding the power button in for several seconds) to turn it off. This will allow your Pinetab to charge without being powered on. | |||
=== Display rotated 90° on Arch ARM === | === Display rotated 90° on Arch ARM === | ||
Line 211: | Line 218: | ||
This command does not persist a reboot. | This command does not persist a reboot. | ||
=== Opening Pinetab === | |||
Be very careful here. It is not a 'pop off' cover design. | |||
Special care should be directed to AVOID anything that may appear to cause a "bend" in screen. | |||
Gently use fingernails (or if you have one, plastic pry), starting in the very middle location for each side (saving keyboard connector latch over area (bottom side) for the very last removal step). | |||
Work your way from the inner middle on each side, slowly. Slide gently towards the direction of each corner (saving the lifting of actual corners themselves for the second to last step)). Careful not to break thin speaker wires that line the outside of the inner case. | |||
The very last opening piece should be the "latch over" (where the keyboard pins connect). | |||
KEEP IN MIND: The main key here is to avoid any potential "bend" of the screen. We save the corners until after working on the middle of each side to reduce pressure on the screen. | |||
Do not force anything. If it is not coming off with gentle effort, you are likely doing something wrong (try another side middle). | |||
== External Links == | == External Links == | ||
* [https://pine64.com/product/pinetab-10-1-linux-tablet/ The PineTab on the Pine64 store] | * [https://pine64.com/product/pinetab-10-1-linux-tablet/ The PineTab on the Pine64 store] | ||
* [https://forum.pine64.org/forumdisplay.php?fid=140 The PineTab section of the Pine64 forums] | * [https://forum.pine64.org/forumdisplay.php?fid=140 The PineTab section of the Pine64 forums] | ||
* [https://forum.pine64.org/showthread.php?tid=11401 Comments on back cover removal on forums] | |||
* [https://forum.pine64.org/showthread.php?tid=13118 Demonstration Video: Pinetab back cover removal on forums] | |||
[[Category:PineTab]] [[Category:Allwinner A64]] | [[Category:PineTab]] [[Category:Allwinner A64]] |
edits
