Difference between revisions of "PinePhone"
40 bytes added ,  06:22, 25 May 2021
Line 282: Line 282:
The phone ships with a protective plastic sticker between the battery and the phone to protect the device from turning on during shipping.. You need to gently open the back cover, then remove the battery and finally remove the sticker and check that the pins aren't bent. Note: If the battery is stuck inside the phone, the mid screw in the lower part of the midframe needs to be slightly loosened, see [[PinePhone_FAQ#The_battery_is_stuck_inside_the_phone|here]].
The [https://files.pine64.org/doc/datasheet/pinephone/PinePhone%20QZ01%20Battery%20Specification.pdf supplied battery] is meant to be compatible with Samsung part number EB-BJ700BBC / BBE / CBE from the 2015 J7 phone. The extended life aftermarket BBU does fit, although it is a tight fit.
The [https://files.pine64.org/doc/datasheet/pinephone/PinePhone%20QZ01%20Battery%20Specification.pdf supplied battery] is meant to be compatible with Samsung part number EB-BJ700BBC / BBE / CBE with dimensions 76.17 x 63.23 x 4.71 mm from the 2015 J7 phone. The extended life aftermarket BBU does fit, although it is a tight fit.
4
edits
Navigation menu
