Difference between revisions of "PinePhone MMS with Matrix"
Line 187: Line 187:
matrix-synapse 1.29.0-1, fractal 4.4.0-2, kop316 mmsd v0.3 -- Works, but images don't go through.
On mobian I'm using matrix-synapse-py3 1.30.0+bionic1 (on a remote VPS server), fractal 4.4.0-2 (and saving the login actually works), kop316 mmsd 0.1-2.2, and images DO go through.
On mobian I'm using matrix-synapse-py3 1.30.0+bionic1 (on a remote VPS server), fractal 4.4.0-2 (and saving the login actually works), kop316 mmsd 0.1-2.2, and images DO go through. with matrix_synapse-1.32.2 from pip installed locally images are received but broken links are sent.
Going to try to downgrade mmsd and see if that helps... It does not. Might be worth trying a newer synapse on arch through pip. Maybe some support libs are missing? I'm working on redoing all of this for mobian.
41
edits
Navigation menu
