Page history
28 May 2022
19 May 2022
24 April 2022
23 April 2022
→Privacy switch configuration: label
+11
→First time setup: size fix
→First time setup: restructure
+729
17 April 2022
13 April 2022
12 April 2022
→Using Factory Test Build for Battery charging: reduced image size
+6
→Factory Test Build for Hardware Checking: reduced image size
+24
→Software: Reworked installation instructions as via draft and chat discussion
+1,039
→First time setup: order
+6
→First time setup: reduced size, simplified instructions
−259
→Installation instructions: Minus warning due to increased software stability
−145
→Flashing to the eMMC: Increased OS stability -warning
−186
11 April 2022
18 March 2022
+261
→Factory Test Build used for Battery charging
+1
+1,099
15 March 2022
+13
−15
+66
+219
no edit summary
+1,058
4 March 2022
→Boot order: style fix
−2
−10
→Boot order: lang fix
+7
→Boot order: updated section
−163
1 March 2022
22 February 2022
→Help and support: new wording
+6
Undo revision 12572 by Jwillikers (talk) -> The Pro is still not using the RK3399, omission is intentional
−7
20 February 2022
Clarify that the boot sequence details link refers to the RK3399 in general and not specifically to the PinePhone Pro
m+7
Reference partition of mmcblk instead of nvme when referring to the SD card for clarity
m
12 February 2022
→Flashing to the eMMC: fix
→Flashing to the eMMC: wording changed due to common concerns
+20
→Bypassing the eMMC: Restructured introduction sentence as it caused confusion and different OSes having a different default behavior -> Power key is already explained in the Boot Order section.
−298
7 February 2022
6 February 2022
→First time setup: plural
+1
→First time setup: added a sentence
+102
Undo revision 12469 by Boot loop (talk) Text is not seen under the images, order is order of importance and how recently issues come up. Stop pushing stuff around, thanks. There is a reason why stuff is ordered a specific way
→First time setup: : reordered sections so that it's [info about battery] [info about sim] instead of what is currently there ([info about battery] [info about sim] [back to info about battery]). This is a change I already made recently but was reverted by Fxc where he reverted other larger changes, I think that's fair but I can't see a reason why this would be reverted. Would like to discuss this change but don't know how to message Fxc. Why revert this change ?
m→Components: reordered list
→Boot order: omission is intended, different SoC variant
−9
Undo revision 12453 by Boot loop (talk) Not an improvement, excessive usage
−76
Undo revision 12449 by Boot loop (talk) Not an improvement
Reverted edits by Boot loop (talk) to last revision by Fxc
m+355
5 February 2022
Adds link to flashing to the eMMC
m+38
Removed a duplicate section (had the same information) to keep one source of truth for bypassing the eMMC
m−770
