SOQuartz Software Releases
Revision as of 22:54, 25 August 2022 by Tizilogic (talk | contribs) (Add link to a working, custom Debian based image)
Manjaro ARM
Manjaro ARM is a user friendly rolling release distribution, based on Arch Linux ARM.
Release 20220718 and older don't boot on SOQuartz. If you find any image that works please update this page with the details.
pgwipeout's Quartz CI
pgwipeout's Quartz CI includes a Debian installer image for the SOQuartz, with the CM4 I/O board as the base board. To download, click the "Download artifacts" button on the right hand side, unzip the archive and take a peek inside the "images" folder to see the selection of pre-built images. Assuming your target device is /dev/sdX, you can flash it with:
sudo -i
xzcat /path/to/rk3566-soquartz-cm4.dtb.img.xz > /dev/sdX
You will need 3.3V UART at 1.5 mbauds (1500000) to access the interface.
Currently the latest image built on 16.07.2022 doesn't work. If anyone manages to get it working please update this page with the details of which release works.
Custom Debian image from user PBXForums
PBXForums shared a custom built Debian image that appears to work to some degree in this GitHub issue:
