SOQuartz Software Releases
Revision as of 21:25, 26 April 2022 by CounterPillow (talk | contribs) (→‎pgwipeout's Quartz CI: sdb -> sdX, actual linebreak for sudo -i)
pgwipeout's Quartz CI includes a Debian installer image for the SOQuartz, with the CM4 I/O board as the base board. To download, click the "Download artifacts" button on the right hand side, unzip the archive and take a peek inside the "images" folder to see the selection of pre-built images. Assuming your target device is /dev/sdX, you can flash it with:
sudo -i
xzcat /path/to/rk3566-soquartz-cm4.dtb.img.xz > /dev/sdX
You will need 3.3V UART at 1.5 mbauds (1500000) to access the interface.
