SOQuartz
Revision as of 14:19, 20 August 2024 by Dsimic (talk | contribs) (→‎Expansion Ports: There's also HDMI)
The SOQuartz
The SOQuartz is a RK3566 based compute module and parts of Quartz64 series.
Software releases
The SOQuartz software releases can be found in the article SOQuartz Software Releases.
SoC and Memory Specification
  • Supports Vulkan 1.0 and 1.1
Neural Process Unit NPU Capability
  • RAM Memory Variants: 2GB, 4GB, 8GB LPDDR4.
  • Storage Memory: optional 128Mb SPI Flash and optional eMMC module from 8GB up to 128GB
Network
  • 10/100/1000Mbps Ethernet
  • WiFi 802.11 b/g/n/ac with Bluetooth 5.0
SOQuartz exposed peripherals
Displays / Cameras
  • 1x HDMI
  • 2x DSI
  • 1x eDP (Instead of HDMI1)
  • 1x LVDS (not available when dual-mode DSI)
  • 1x CSI 4-line
Connectivity
  • 1x Ethernet (1Gbit)
  • 1x USB 2.0 OTG
  • 1x SD Card (SD)
  • 1x PCIe 1-Line
  • 28x GPIO (TBD)
Connector Pins Definition
SOQuartz Model-A Baseboard Features
  • Model "A" Baseboard Dimensions: 133mm x 80mm x 19mm
  • Input Power: DC 12V @ 3A 5.5OD/2.1ID (IEC 60130-10 Type A) Barrel DC Jack connector
Storage
  • microSD - bootable, support SDHC and SDXC, storage up to 2TB
  • USB - 2 USB2.0 Host port
Expansion Ports
  • MiPi-CSI - 1x 2 lanes, 1x 4 lanes
  • MiPi-DSI - 1x 2 lanes, 1x 4 lanes
  • 2x20 pins "Pi2" GPIO Header
  • PCIe 1x open ended slot
  • 1x5 pin USB Expansion Header (J15)
GPIO Pins
Attention! GPIOs are 3.3V!
Interesting alternate pin configurations are listed in [brackets].
Assigned To Pin no. Pin no. Assigned To
3.3 V 1 2 5 V
[I2C2_SDA_M1] GPIO4_B4_3V3 a 3 4 5 V
[I2C2_SCL_M1] GPIO4_B5_3V3 a 5 6 GND
[GPCLK0] GPIO4_A4_3V3 7 8 GPIO0_D1_3V3 [UART2_TX_M0]
GND 9 10 GPIO0_D0_3V3 [UART2_RX_M0]
[I2S1_MCLK_M1] GPIO3_C6_3V3 11 12 GPIO3_C7_3V3 [I2S1_SCLK_M1]
GPIO4_A0_3V3 13 14 GND
GPIO4_A2_3V3 15 16 GPIO4_A3_3V3
3.3V 17 18 GPIO4_A1_3V3
[SPI3_MOSI_M0] GPIO4_B2_3V3 19 20 GND
[SPI3_MISO_M0] GPIO4_B0_3V3 21 22 GPIO4_B1_3V3
[SPI3_CLK_M0] GPIO4_B3_3V3 23 24 GPIO4_A6_3V3 [SPI3_CS0_M0]
GND 25 26 GPIO4_A7_3V3 [SPI3_CS1_M0]
[I2C3_SDA_M0] GPIO1_A0_3V3 a 27 28 GPIO1_A1_3V3 [I2C3_SCL_M0] a
GPIO3_A5_3V3 29 30 GND
GPIO3_D4_3V3 31 32 GPIO3_D6_3V3
GPIO3_D7_3V3 33 34 GND
[I2S1_LRCK_M1] GPIO3_D0_3V3 35 36 GPIO3_D5_3V3
GPIO3_D3_3V3 37 38 GPIO3_D2_3V3 [I2S1_SDI_M1]
GND 39 40 GPIO3_D1_3V3 [I2S1_SDO_M1]
Notes
  1. pulled high to 3.3V through 2.2kOhm resistor
Source: Page 11 of the board schematics.
Pin no Assigned To
1 USB2_HOST_5V
2 HOST_DM3
3 HOST_DP3
4 GND
5 GND
Source: Page 10 of the board schematics.
SOQuartz BLADE Baseboard Features
  • SOQuartz BLADE Baseboard Dimensions: 200mm x 40mm x 15mm
  • Input Power:
    • DC 5V @ 3A 3.5OD/1.35ID (IEC 60130-10 Type H) Barrel DC Jack connector
    • PoE
Storage
  • USB - USB2.0 Host port (with header for setting OTG ID pin)
Expansion Ports
  • HDMI video output
  • M.2 slot
  • PWM fan header
Jumpers
  • OTG ID jumper
  • GPIO voltage, select 3.3V or 1.8V
  • PoE Enable
SOQuartz Module and Baseboard Information, Schematics, and Certifications
SOQuartz BLADE 3D Print 1U half width server rack
SOQuartz BLADE 3D Print 1U full width server rack
SOQuartz module certifications:
SOQuartz Module with various CM4 carrier boards
SOQuartz with DF Robot CM4 Carrier Board
SOQuartz with Waveshare CM4 Carrier Board
SOQuartz with Waveshare CM4 PoE Board
BSP Linux SDK
BSP Linux SDK ver 4.19 for Quartz64 model A SBC
Android SDK
Android 11 SDK for Quartz64 model A SBC
How-To
Building Mainline U-Boot
See Quartz64 Building U-Boot.
Troubleshooting
This section provides information on troubleshooting various common issues you may encounter using the SOQuartz.
Thermal Issues
The SOQuartz SoM does not have a lot of copper to sink heat into. Therefore, it's recommended you use a heatsink such as the Waveshare CM4 Heatsink, the other Waveshare CM4 Heatsink, or the PINE64 Small Fan Type Heatsink. Please be aware that the Waveshare heatsinks may interfere with any eMMC module, unless you use very thick (2-3 mm?) thermal pads. Local resellers may sell CM4 heatsinks or small stick-on heatsinks, so there's no need to order them from abroad unless it's cheaper.
Alternatively, or in addition to this, a rectangle-shaped piece of 1 mm thick thermal pad can be sandwiched between the SoM and the carrier board. This allows the SoM to more efficiently sink heat into the larger mass of the base board.
